STM32 MCUs Products
Stop mode and peripheral clocks
 Hi. I'm looking for guidance on entering and exiting Stop mode. L4, but probably applies more broadly. The RMs explain how to enter it, but I'm unclear on RCC effects.PLL oscillators other than HSI or MSI (depending on family) are disabled and desel...
DOCon.1 by Senior
  • 1845 Views
What kind of wire could I use to power my STM32F769I-DISCO?
Hello! I've bought that kit and I would like to know where I can find the kind of wire which could enable me to power it without using either USB ports or Ethernet one.Below a picture which shows you this input with the mention "5 V power supply inpu...
LleytoN by Associate II
  • 720 Views
Resolved! PWM gating by other timer on STM32L412
Hello,In my project I need to generate 1s on, 1s off PWM signal in hardware.First I checked if my PWM works with simple project, and it does.But following AN4776 for N-pulse waveform generation application example - part 1.LL_APB2_GRP1_EnableClock(L...
Linas L by Senior II
  • 880 Views
  • 3 replies
Unused pins connected to ground. Could they cause short?
I just had my first STM32 pcb done and I've been following the reference designs and checked many times everything that there is no shorts etc. However when I power the circuitry 3.3V side draws >200mA and the STM32L4S5ZIT6 does heat up when looked t...
VVest.1 by Associate II
  • 5237 Views
  • 12 replies
Optimization for the speed of the printf function.
Hi.Faced the problem of prinyf () function execution speed.Wrote a simple speed testHAL_GPIO_TogglePin (GPIOE, GPIO_PIN_8);uint8_t text [256] = {0};for (uint32_t i = 0; i <256; i ++){sprintf (text, "% - 5.2f", (i + 10.0 / 2.0));}HAL_GPIO_TogglePin (G...
