STM32 MCUs Products
Specifying the Interrupt priority.
Hi every body. I want to manage two events with general purpose timers 16 and 3. As a convention in ARM processors, as much as I know, the lower interrupt number corresponds to the higher priority. So I think I need to manage event with higher priori...
STork.1 by Associate III
  • 10945 Views
  • 1 replies
STM32H743 AXI QOS
Hi,In RM0433 Reference Manual there is a description of the AXIM indicating the possibility to change the QoS for the AXI switch matrix, but cannot find the reference for the indexes used in AXI_INIx_READ_QOS or AXI_INIx_WRITE_QOS.If there any manual...
LGarc.2 by Associate
  • 1255 Views
  • 3 replies
Resolved! My SPI clock produce 16bit rather than 8bit
I have a problem where my SPI clock produce 16bit, where I already set it to 8bit. I am not using any HAL driver, but I am learning from online course to develop my own driver from scratch.I have a problem at SPI master slave.The program is like this...
WM_IR by Senior
  • 931 Views
  • 3 replies
I am having an issue doing the firmware update by OTA with my own code in BlueNRG-LP using Steval-IDB011V1 and BlueNRG-GUI app.
If I use the example BLE_Sensor_Demo + OTA_Reset_Manager I can update the firmware without any problem. I have followed the indications given in The BlueNRG-LP (over-the-air) firmware upgrade document (AN5463) and I don’t see any difference between m...
ARamí.1 by Associate II
  • 615 Views
  • 0 replies
Resolved! Pin Compatible Alternatives to STM32F765VIT6?
Due to the global chip shortages, we need to purchase a pin-compatible (LQFP100) version of the STM32F765VIT6. Since we don't need the 2k Flash we are looking at the STM32F7767VGT6, or the STM32F746VGT6. Both appear to have the same essential archite...
