STM32 MCUs Products
How to stop writing in memory where DMA can't access
Hi guys, I'm having this issue where I kept getting a Transfer Error when setting up a DMA.One of the replies I got is that DMA1 can't reach the memory area of DTCM, which would explain why it can't transfer the context from the buffer into the peri ...
CLeo.1 by Senior II
  • 718 Views
STM32L4R5 Quadrature Encoder Hardware Connection
I'm trying to connect a quadrature encoder to my board using STM32L4R5. From what I understand, I should connect the A and B to TIM2, TIM3, TIM4 or TIM5. If I have 2 encoders, can I connect all 4 A and B signals from both encoders to the same TIM? Li...
CYeow.1 by Associate II
  • 899 Views
Resolved! Can't enable DMA stream for UART4 Tx
Currently I am using the STM32H753ZIT6 to do all the bare metals. Essentially what I am trying to do is just enable UART4 Tx to send some debug messages thats all. Everytime I try to enable the DMA1_Stream3 (UART4_Tx) it just gives me a TEIF3 error a...
CLeo.1 by Senior II
  • 1418 Views
  • 7 replies
5V-tolerant input pulls 5V down to 4V
Hi all:I am using an STM32407 running at 3.3V, and I have 2 inputs connected to 5V signals.One of the signals comes from an outside sensor (a data line), and the other one is connected to a 5V optocoupler populated on the same board.I have measured t...
Diez.R. by Associate II
  • 3031 Views
  • 8 replies
Resolved! State of UART pins during a reset on STM32F439
I am having a hard time finding out the state of the UART pins while the chip is held in RESET. Are pins E2, D5, D4, and E1 held in a high-impedance state while the RESET pin H9 is pulled low? I suspect they are, but am trying to confirm through docu...
LKish.1 by Associate
  • 1749 Views
  • 3 replies
I2C stm32F103
Hi,i come up with my question related to I2C communication using stm32F103,I would like to interface my I2C LCD (slave) with MCU ( master), but i have a problem with the Transmit sequencei have configured the GPIO's PB6 (SCL) and PB7(SDA) as open dra...
SIDRI.1 by Associate III
  • 1053 Views
  • 0 replies
digital clock in custom container
Hi, I have a custom container that includes a digital clock. But when I set the clock any initial time, it starts from 00:00:00. How do I set the clock to the initial time that I want?
Ezgi by Senior
  • 540 Views
