STM32 MCUs Products
STM32h7 Multichannel ADC DMA is not working.
Hi,I am try to read four ADC Channels of ADC3 using DMA method. But I did not get the data.Below is my programmingstatic void MX_ADC3_Init(void){ ADC_ChannelConfTypeDef sConfig = {0}; hadc3.Instance = ADC3; hadc3.Init.Resolution = ADC_RESOLUTION_16B;...
MDeva.1 by Associate II
  • 2127 Views
  • 3 replies
UART transmit works succesfully but reciever don't
The device I am using is F303K8T6.I am trying to learn. I have no problem with transmitting.But when it comes to receive data it don't works. Interrupt not rises.But when I connect tx pin to rx pin it works well. Interrput rised. The code and concern...
SinanOZ by Associate
  • 815 Views
  • 1 replies
STM32 H745. Is it possible to trigger a dma transfer from memory to SPI on rising/falling edge of pwm generated from a timer?
Hello, I'm having trouble reading from external ADC which needs a maximum time of 10ns from the falling edge of command (I'm giving it from a TIM4 PWM mode 1, 300ns active, 100kHz frequency). I'm using TIM3 as a slave timer from TIM4, one shot and TI...
EDallaVia by Associate II
  • 1305 Views
  • 3 replies
What is the maximum main frequency of the STM32H7 devices, and if this frequency can be output by any of the devices pin?
What is the maximum main frequency of the STM32H7 devices, and if this frequency can be output by any of the device's pin and if this frequency can be input by any pin of the device. By the way, the project we are working on need the frequency is th...
xzhan.22 by Associate
  • 1093 Views
Encoder read error
Hi there!i start to work with a rotary encoder, i configurate a timer 3:in this way and i enable the interrupt . for read the encoder inside the timer interrupt i write nuber= (TIM3->CNT)>>2;so when i read the varible the first time i see 0 - 1- 2- 3...
SGian.1 by Senior
  • 1204 Views
  • 3 replies
Resolved! Powering STM32 Blue pill through external source via micro USB
Hello, I've a strange problem and I can't find the answer on internet.I'm transmitting a data from UART2 of my STM32 Blue pill. Its just one line :- HAL_UART_Transmit(&huart2, (uint8_t*)Tx_msg, sizeof(Tx_msg), 100);While using with ST-Link, it works....
Mshar.2 by Associate II
  • 3138 Views
