STM32 MCUs Products
Resolved! Software PWM, best approach?
It finally happened, i need two pins without pwm functionality to output pwm signals (minimum 1kHz)Im using an STM32f072R8Tx clocked with HSI48Mhz, my TIM1 is available.My idea is:TIM1 channels 1 and 2 set up as PWM NO OUTPUT with interruption enable...
Javier1 by Principal
  • 3794 Views
  • 12 replies
  • 1 kudos
Resolved! Quickest way to set multiple port pins
Hi,I am trying to connect to a 16 bit parallel display interface. To write new data, I have to use pins on five different ports (GPIOs A, B, C, D, E). Right now I am setting these pins like this:PORT_D15->BSRR = (PIN_D15 << 16) | (((data >> 15) & 0x...
STM32L5 FDCAN Message RAM access failure
Hello,I've been using the STM32L5 FDCAN HAL Driver but I have some problems with it.When i try sending some CAN 2.0 frames to the STM32, an isr is called and the error Message RAM access failure is raised.Sometimes, the ACK is sent but the interrupt ...
ABouk.1 by Associate III
  • 653 Views
  • 1 replies
Resolved! (Solved) SAI receiver and circular DMA
Hello,I am working on SAI part of the NUCLEO-F756ZG board and I observe an issue with the DMA.The configuration is:SAI A as a master with master **** out and audio mode = master receive. SAI B as asynchronous slave and audio mode = slave transmit. (S...
