STM32 MCUs Products
Resolved! STM32F303RE Tim2 ch2 PWM Mode
Hi everyone, I'm trying to use the Timer2 CH2 PWM Mode 1 to generate a 1 Hz signal with 50% Duty Cycle out of my PA0 pin but i can't get anything. Here's my code:#include"stm32f3xx.h"   void TIM_PWM(void);   int main(void){ TIM_PWM(); while(1){ } }...
Nick- by Associate II
  • 1145 Views
Resolved! How get the List file from assembler?
HelloI'm using CubeIDE.I want to get list file which is containing OP code from "Startup_stm32f427zgtx.s" as a output of assembler.I heard that I could use -Wa, -al option here and there on the Webs, but I couldn't get the list file of the assembler....
SSeo.17 by Associate III
  • 1084 Views
STM32F3 SPI3 not working
Hey,I'm working with STM32F303RET6.I'm having trouble transmitting data with SPI3 (PB3, PB4, PB5 and PA15).Before I'll post my code here, I want to say that I am also working with SPI2 (PB12, PB13, PB14 and PB15) with the exact same configuration on ...
RLosc.1 by Associate II
  • 1227 Views
  • 5 replies
Resolved! Circular buffer resetting start point?
I'm trying to use DMA to handle my incoming Rx data and, ideally, I'd like to just increment the index to keep track of the incoming data, essentially like this:#define uartsize 2000 #define dma_buffer_interrupt_size 1   uint8_t UART_in_Buffer[uarts...
JayDev by Senior II
  • 1823 Views
STM32L4Rxxx OctoSPI with PSRAM
Dear All,In "RM0432 Reference manual STM32L4+ Series advanced Arm ® -based 32-bit MCUs" in chapter "19.3 OCTOSPI implementation" and table "Table 119. OCTOSPI implementation" there are some differences in supported features between families. All fami...
Resolved! INVPC occurs when SVC Handler returns
I use STM32F1 Value Line Discovery Kit.​I want to write SVC handler.If I implement the following, invpc occurs when running 「POP PC�?in Line 38.Caller -------------------------------- __asm volatile(" SVC %0 \n" : : "I" (2)); ...
Myasu.1 by Senior
  • 645 Views
  • 4 replies
