STM32 MCUs Products
Problems with CAN TX on Nucleo F767ZI
Greetings,I have a project on the Nucleo F767ZI board where I try to send a CAN message to another device (in particular, an Maxon EPOS4 Compact 50/5 drive). I can receive messages from this device with no problem, however, as soon as I press the but...
luisegzb by Associate
  • 207 Views
  • 1 replies
  • 1 kudos
Resolved! STM32L0 wake up pin 1 (PA0) not working?
Hi, I would like to use system wake-up pin 1 (PA0) as an external interrupt to wake up my MCU from standby mode. Understand that a rising edge on PA0 (wake-up pin 1) should trigger the MCU to exit standby mode. However, I am encountering difficulties...
chai2145 by Associate III
  • 707 Views
  • 14 replies
  • 6 kudos
Cannot set deadtime for HRTIM1 in NUCLEO-G474
Hello,I have the NUCLEO-G474RE kit and am trying out basic exercises such as toggling GPIO pins, setting up timers and generating PWM gating pulses. I got GPIOs and timers working. I got basic complementary PWM working on Channel A with the HRTIM. Bu...
SKI by Associate
  • 136 Views
  • 1 kudos
Resolved! STM32H743 external loader
I went through the ST External QSPI Loader how to and have verified my quadspi.c/h driver is good with the Winbond W25Q64 flash part we are using.  However after I create the .stldr and load it into the STM32 Programmer it will not read from the flas...
PFlor.2 by Senior
  • 3211 Views
  • 20 replies
  • 2 kudos
STM32F746IGT Boot configuration issue?
Hello you guys.I’m having trouble operating the STM32F746 board.I designed an embedded board using the STM32F746 and attempted to control LEDs through CubeIDE. While compilation and program uploading were successful, the LEDs do not function at all.I...
toywars0_0-1733888685456.png toywars0_4-1733889038144.png toywars0_3-1733888959345.png toywars0_6-1733889312495.png
toywars0 by Associate
  • 106 Views
ST future ARM Cortex M55/M85 line?
Are there any plans for ST to release an ARM Cortex M55 or (more hopefully for me) an ARM Cortex M85 line?I am extremely interested in their number-crunching and vectorization features, and am very keen to see how they would perform in a real-time au...
etheory by Senior II
  • 9887 Views
  • 7 replies
Resolved! Struggling with CAN Filter
Dear Community,   Once again I am struggling with CAN Filters for extended IDs using CAN2 on a STM32F765. I have the ID 0x010100 and the filter should look like 0xXX0101XX where the X hex should be ignored. One of my early approaches: uint32_t filter...
Anno by Associate II
  • 290 Views
  • 8 replies
  • 7 kudos
STM32L010RB_NUCLEO_PWR_STANDBY
Hello, I have tested the kit discovery  NUCLEO-L010RB and the program PWR STANDBY(mcu STM32L010RB), this work fine. I would like do exactly the same test with the mcu STM32L010K8 (so the same family like STM32L010RB), but I have a problem, the progra...
Resolved! SPI NSSP on STM32F767ZI
Hello,Disclosure: I am fairly new to using STM based Microcontrollers, as well as DMA.I am using an STM32F767ZI MCU on a custom PCB. I am trying to Implement an SPI interface to an DAC Chip (AD5443) through DMA (no interrupts as of the moment). My DM...
sinannov by Associate
  • 167 Views
  • 4 replies
  • 2 kudos
