STM32 MCUs Products
Can't get ADC values
I have an STM32G474RE, I have not used any HAL or LL libraries, I have only programmed using the registers, my issue is that I am only getting 0 on the output of the ADC, I read through the reference manual and still couldn't solve the problem. I hav...
Epsilon03 by Associate II
  • 4030 Views
  • 8 replies
DMA is jamming the RTC
Hello, I have a problem with RTC and UART reception using the DMA.I am currently working with the L476RG core board. The RTC clock is the LSE. The UART is configured in cyclic mode on the Rx PIN.I have done a simple data logging and could check that ...
_legacyfs_online_stmicro_images_0693W00000dDcblQAC.png _legacyfs_online_stmicro_images_0693W00000dDccKQAS.png
JFlui.1 by Associate II
  • 1035 Views
Resolved! How to call timer interrupt using registers? [NO HAL DRIVERS]
Hi, i am trying to call timer interrupt handler using registers and the following is my code, but the problem is that the function is being not called, I see no output in the oscilloscope or live expression. First my DAC value is still 0, the counter...
RShre.2 by Associate III
  • 5078 Views
  • 7 replies
Resolved! How to read GPIO direction using HAL?
Hello world,I'm developing a FW for STM32F107VCT6 which can change GPIO direction programmatically: there is a terminal command which can switch individually 7 pins* mapped on different ports between GPIO_MODE_OUTPUT_PP \ GPIO_MODE_INPUT.I'm wonderin...
Spaghetto by Associate III
  • 2119 Views
  • 3 replies
  • 2 kudos
Resolved! H743zit6, Abnormal data reception using SPIDMA mode?
All data received in normal mode is 0, but some correct data can be received in debug mode? cubemx configurations are as follows:Part of the code is as follows:uint8_t pData[128] = {0x00}; HAL_SPI_Receive_DMA(&hspi1,pData,128); while(HAL_SPI_GetStat...
_legacyfs_online_stmicro_images_0693W00000dDSVYQA4.png _legacyfs_online_stmicro_images_0693W00000dDSVdQAO.png _legacyfs_online_stmicro_images_0693W00000dDSViQAO.png _legacyfs_online_stmicro_images_0693W00000dDSWMQA4.png
AASD.1 by Associate III
  • 2760 Views
  • 5 replies
Resolved! How to accurately determine whether comparator interrupt was generated by rising or falling in the interrupt routine
I use comparator(COMP7) on STM32F303VB as・Non-inverting input: PC1 (ADC)・Inverted input: DAC2 output・Comparator interrupt: rising/falling edge triggerI checked the COMP7OUT bit, but it seems that this bit is "comparator output at the time the bit is ...
Dai by Associate II
  • 1870 Views
  • 4 replies
