STM32 MCUs Products
800 x 800 Display with STM32U5G9VJT6Q - possible?
Hi,we are trying to get a 800x800 display to work with the STM32U5G9VJT6Q, using either RGB888 or RGB565 in Video Mode (Burst).According to what we read it is definitely possible. Did we miss something?Could someone please confirm that is definitely ...
Ricko by Senior III
  • 3842 Views
  • 32 replies
  • 16 kudos
Resolved! STM32 ADC VREFINT / TEMP reads maximal value 4095
Hi,I’m trying to read internal temperature sensor on ADC1, but the ADC result is always 4095.I use STM32L471, and I know that the problem is not HW related, when I run a different bin it reads the temp ok.Tried to read VREFINT, raw value is also 4095...
Screenshot 2026-01-20 152910.png Screenshot 2026-01-20 153102.png Screenshot 2026-01-20 155308.png
Stm32h743ii serie with QSPI memory W25Q256JV
Hello all  Hardwarestm32h743iitxflash : W25Q256JV sdRam: w9825g6kh lcd : 7 pouces no driver 24bit parrallel I have dev a stm32h743ii pcb with a 7 pouces 24 bit lcd . the basic debug work for the lcd and sdramWhere i am facing problem is on flash W25Q...
KNaim.1 by Associate III
  • 184 Views
  • 1 replies
IAP over SPI stm32u5
 I need support to get IAP over SPI.I've esp connected to my stm32u5 over SPI. Stm is slave and ESP is master. For stm I've created project using stmcube by entering MCU part number.Now here my question is1. Do I need to develop bootloader code to ac...
Multiple ADC Channels reading same values
Hi I'm using STM32G0B0RET6, and im using ADC Channel 1,4,5,6,7,10,11,15, and 16 . and sequencer is set to not fully configurable because if set to fully configurable then i can't use Channel 15 and 16.So here for all ADC channels i'm getting same val...
FW1 by Associate
  • 121 Views
