STM32 MCUs Products
Resolved! STM32H7 UART/USART not working with GPS module (MAX-M10M )
Hi,I have connected a MAX-M10M  module to an STM32H7  MCU ( it's custom board) by UART port. I am able to send data to GPS module and also receive config data of it but not able to receive NMEA packets. I only receive the first byte and then the HAL_...
amirshn by Associate III
  • 1516 Views
  • 10 replies
  • 4 kudos
Resolved! G484 Uart transmit 0x00 not sent/received
Hello, trying to send array below. The '0x00' part is not received in terminal, see image below.   char binary_data[] = {0x01, 0x02, 0xAB, 0x00, 0xCD}; HAL_UART_Transmit(&huart5, binary_data, sizeof(binary_data), HAL_MAX_DELAY); How can I get this t...
Resolved! How to run a program in sdram on STM32H743 ?
Hello guys, recently I designed a PCB board using STM32H743IIT6 and I encounter a problem when I try to run code in sdram. The details are described as below.​question: I have a demand jumping to run a user program(function) in the sdram. B...
Bornason by Associate II
  • 2507 Views
  • 5 replies
  • 1 kudos
Resolved! SWD interface Connector Selection for MCU Bootload
Hi!I have a custom STM32H753ZIT6 MCU based board for which I am using SWD in order to bootload/program the MCU. To interface the SWD to either the STLINK or other programming modules similar to it, does anyone have any recommendation on what connect ...
hvs_learn by Associate III
  • 332 Views
  • 3 replies
  • 1 kudos
