STM32 MCUs Products
Attempting to change the UART port of a sample
Greetings,I want to compile the BLE Transparent Mode sample from the Cube (Version: 1.13.1Build: 17479_20230728_0839 (UTC)) for the STM32MMB module that has a different UART port from the default which is PB6/7.  Our design uses PA9/10 because we nee...
eleventen by Associate III
  • 1218 Views
Resolved! SPI debugging stops after around 125 bytes being send
Hi STM forums,I use a stm32f205rct6tr for this projectin my project i need to send 1024 clock signals to the slave, the message inside is not inportant.but after sending around 125 bytes it stops debugging entirely, i checked it out with the oscillos...
Resolved! ATM32H747xi datasheet Table 9. Port A - Question
In the ATM32H747XI datasheet Table 9 on page 89...As I read this table... Examples are...Pin Name PA1 Alternate Function AF1 = TIM2_CH2Pin Name PA2 Alternate Function AF2 = TIM5_CH3Question 1:For PA0 AF1, there are two functions listed... TIM2_CH1/TI...
Will_iii by Associate II
  • 1209 Views
  • 1 kudos
How to detect what level digital input caused interupt
Hi  I have pin PA6 setup to interupt on high and low levels. I have done the following:GPIOA->MODER &= ~GPIO_MODER_MODE6; //PA6 as inputSYSCFG->EXTICR[1] &= ~SYSCFG_EXTICR2_EXTI6; //PA6EXTI->RTSR1 |= EXTI_RTSR1_RT6; //enable rising edgeEXTI->FTSR1 |=...
STM32F103ZET6 - Interface with LCD driver Ilitek ILI9341
Hi,I have inherited a project that utilizes Nuttx RTOS. This project is to change out the LCD display due to EoL. We are changing from Renesas R61580 Driver to Ilitek ILI9341. The existing driver is hooked up via 16-bit MCU command via the FSMC, with...
JT-88 by Associate
  • 1447 Views
  • 1 replies
SDCard initialization issues
Hi everyone,I am encountering issues in sdcard initialization on my custom board.I am getting SDMMC_FLAG_CTIMEOUT error in SD_PowerON once the first CMD8: SEND_IF_COND is sent.Looking at signals and comparing with an identical custom board, you can s...
lukin by Associate III
  • 695 Views
  • 0 replies
Resolved! GND diference
There are no diference for conect to gnd in the left side o right side?
wjian.2 by Associate III
  • 970 Views
  • 1 replies
G.722 vocoder
Hello,I've seen the AN4229-how-to-implement-a-vocoder-solution note, which talks about support for G.711 and G.726. Does anyone know if anything is available specifically for G.722?Thanks
EC.3 by Associate III
  • 930 Views
  • 0 replies
How to index different GPIO ports in one array
hi everyone.I'm trying to index different GPIO ports and pins.  #define STEP1_HALF1_PORT GPIOA#define STEP2_HALF1_PORT GPIOB#define STEP3_HALF1_PORT GPIOA#define STEP4_HALF1_PORT GPIOC#define STEP5_HALF1_PORT GPIOBGPIO_TypeDef *Half1StepPortNum[5] = ...
