STM32 MCUs Embedded software
Resolved! stm32h745 eth freertos+tcp freertos + lwip
Hello,I am new to the STM environment and need to test if one M7 core is sufficient for my project. I need to use Ethernet (simple GET, POST, and PATCH requests), an LCD touch panel, and a peripheral that requires EXTI interrupts approximately every ...
RafaelS by Associate III
  • 22 Views
  • 1 replies
Voice compressing in STM32L4
I need to compress voice in STM32L4. Here are my requirements:* STM32L4 run at maximum 80 MHz* Voice to be sampled by ADC/DMA* Flash usage for voice compression < 50 kBytes* RAM usage for voice compression < 64 kBytes* Compressed data < 10% of origna...
RFlod.2 by Associate II
  • 145 Views
  • 6 replies
Configure peripherals after sleep
Hi everyone,During developing applications with STM32l476, using HSI16, I choose STOP1 or STOP2 mode to reduce power consumption , and wake up with RTC Alarm.if (HAL_RTC_SetAlarm_IT(&hrtc, &sAlarm, RTC_FORMAT_BCD) != HAL_OK) { Error_Handler(); } ...
path321 by Associate II
  • 16 Views
  • 1 replies
STM32C031C6 ClassB Example Code
Hi Community,I came a cross with a strange error that I can not understand the reason.As I search the read me file of the example project which is shared by ST.It is written as below.2. load the image into the target3. Execute the code- LED4 toggles ...
FDCAN Error Counters
Hello,Where can I find documentation on the error counters of the FDCAN_ErrorCountersTypeDef structure? I would be particularly interested in how the incrementation of TxErrorCnt behaves if hfdcan1.Init.AutoRetransmission = ENABLE; (How often does th...
MFrie.7 by Associate II
  • 73 Views
  • 1 kudos
