STM32 MCUs Motor control
Discuss STM32 solutions for motor control, including PID tuning, sensorless operation, ADC noise, custom algorithms, and more.
User Manual MCSDK documentation
  Dear MCSDK users, The full MCSDK documentation is embedded in the Motor Control Workbench tool. Refer to Workbench tool > About > Documentations > Documentation.This document provides: Introduction: Includes startup guide links for MCSDK, HSO featu...
GMA by ST Employee
  • 1826 Views
  • 0 replies
MCSDK 6.4.0 is out!
Dear MCSDK users, MCSDK version 6.4.0 is now available: Download It here. This version of the new Motor Control SDK 6 series (X-CUBE-MCDSK) provides mainly FOC and 6Step improvements, here are the main changes for this version: Motor Control Features...
GMA by ST Employee
  • 4972 Views
  • 0 replies
  • 3 kudos
Board Manager documentation is out !
The documentation of the Board descriptions format is now available on Motor Control Boards Description Wiki page, this documentation is compatible with MCSDK versions from 6.1.2. Board Descriptions are used by the ST motor-control workbench to enabl...
Zied b. by ST Employee
  • 9736 Views
  • 5 replies
  • 3 kudos
STSPING4 VDS protection triggered.
About EVSTSPIN32G4, I started the code generated by MotorControl Workbench 5. Y.3 normally.If you transplant the IIC configuration of the pre drive and enable PWM output, the VDS will report an error.After carefully reading the generated code, it is ...
GWenJ.1 by Associate II
  • 2057 Views
  • 8 replies
  • 1 kudos
MC Workbench - ACD1/2 porting to ADC12, STM32G474R
EDIT: Resolved! It looks like this was an issue with the pin reporting on our end.  Hello, We would like to use MC workbench, however we want to move from ADC1/2  to ADC12 for the current sense, VBUS and temperature NTC.  Is there a way to implement ...
Hattie by Associate
  • 199 Views
  • 1 replies
STM32 MCUs Motor control WB APP failure error
I have this Fatal Error. Plese help me"  [Fatal Error] 2.STM32CUBEMX.5.6.0.AnalyticsServer.xml:1:1: Premature end of file. [Fatal Error] 2.STM32CUBEMX.AnalyticsServer.xml:1:1: Premature end of file. [Fatal Error] 2. AnalyticsServer.xml:1:1: Premature...
DODOAN by Associate
  • 211 Views
  • 1 replies
Resolved! HSO on G431
Hi,I'm trying to setup HSO on the G431, I used the B-G431B-ESC1 board as a starting guide. I'm trying to use differential sensing with internal OP-AMPs and internal PGA. I have split the currents and phase voltages across ADC1 and ADC2 but I still ca...
sst1010 by Associate
  • 298 Views
  • 1 replies
Resolved! EVSPIN32G06Q2S1 board damaged during power-up
Hi,We were attempting to control a high-voltage BLDC motor using the EVSPIN32G06Q2S1 evaluation board. While following the Getting Started procedure described in UM3394, the board got  damaged during the power-up stage.Below are the steps we followed...
sujay-s by Associate II
  • 731 Views
  • 6 replies
  • 2 kudos
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
