STM32 MCUs Motor control
MCSDK 6.3.2 is out !
Dear MCSDK users, MCSDK version 6.3.2 is now available: Download It here. This is a bug fix release and here are the main changes for this version: Motor Control Features: FOC Fixed CORDIC Modulus computation in case of negative alpha value Fixed iss...
GMA by ST Employee
  • 449 Views
  • 0 replies
Board Manager documentation is out !
The documentation of the Board descriptions format is now available on Motor Control Boards Description Wiki page, this documentation is compatible with MCSDK versions from 6.1.2. Board Descriptions are used by the ST motor-control workbench to enabl...
Zied b. by ST Employee
  • 3909 Views
  • 5 replies
  • 3 kudos
MCSDK documentation and your feedback
Motor Control Wiki: STM32 Motor Control Knowledge Database - stm32mcuMC Frequently asked questions (FAQ):Frequently asked questions (FAQ) - stm32mcu   The documentation of the Board descriptions format is now available on the Motor Control Wiki:   Wi...
  • 5013 Views
  • 1 replies
  • 1 kudos
Resolved! ST Motor Control with STLinkV3
Hi all,I have adapted the B-G431B-ESC1 board into a custom design and I am using a STLINK-V3MINIE for programming. I can program the controller and I can communicate via the serial interface.But ST Motor Pilot V1.2.12 does not detect the UART interfa...
Phase loss Motor
HelloI'm trying to figure out how to detect a phase loss on the motor side. I'm looking for a distinction between "loss of one motor phase" and "loss of all motor phases". This can be recognized quite well from the currents measured using the ADC. Ho...
tV1 by Associate
  • 109 Views
  • 1 replies
Where can I find HW deadtime setting?
We're using a driver that inserts a deadtime by hardware.It is not clear to me how I have to configure that into the MCWB firmware to get ADC measurement working properly.I see three deadtime-related settings:- "minDeadTime" property in the "PhaseVol...
DMeie.2 by Senior II
  • 145 Views
  • 1 replies
Resolved! MCI_SetCalibratedOffsetsMotor
hi everyone,I cant see usage of MCI_SetCalibratedOffsetsMotor or MC_SetPolarizationOffsetsMotor1 in example project, but code comment says use at least one time in product life. Has this been used before? or  "MCI_StartOffsetMeasurments". does anyone...
Zek_De by Senior
  • 95 Views
  • 1 replies
Resolved! Minimum programming configuration for STSPIN32G0601
I have attempted to interface an STSPIN32G0601 using only connections to an ST-LINK (V2).  That is: there are no other connections to the target IC other than SWCLK to PA14 (pin 62), SWDIO to PA13 (pin 61), GND to VSS (pin 8), and 3.3V to VDD (pin 7)...
FMadi.1 by Associate II
  • 208 Views
  • 4 replies
Noisy Torque/Phase Currents
I have a custom board, which is based on the STEVAL-SPIN3201, it is used to control a low inductance BLDC motor with hall-sensors (100µH). The motor controller is running and is able to control the motor. Unfortunately the phase currents tell that th...
Hall Sensor in Steval IPM 30B
I am trying to control BLDC motor with Steval IPM30 B and Nucleo L476RG as controller. In sensor less mode it is working fine but when I am using Hall Sensor it is not rotating at all and its showing speed feedback error at the starting only. How to ...
hu88 by Associate II
  • 228 Views
  • 7 replies
