STM32 MCUs Motor control
MCSDK 6.3.2 is out !
Dear MCSDK users, MCSDK version 6.3.2 is now available: Download It here. This is a bug fix release and here are the main changes for this version: Motor Control Features: FOC Fixed CORDIC Modulus computation in case of negative alpha value Fixed iss...
GMA by ST Employee
  • 1184 Views
  • 0 replies
Board Manager documentation is out !
The documentation of the Board descriptions format is now available on Motor Control Boards Description Wiki page, this documentation is compatible with MCSDK versions from 6.1.2. Board Descriptions are used by the ST motor-control workbench to enabl...
Zied b. by ST Employee
  • 4299 Views
  • 5 replies
  • 3 kudos
MCSDK documentation and your feedback
Motor Control Wiki: STM32 Motor Control Knowledge Database - stm32mcuMC Frequently asked questions (FAQ):Frequently asked questions (FAQ) - stm32mcu   The documentation of the Board descriptions format is now available on the Motor Control Wiki:   Wi...
  • 5338 Views
  • 4 kudos
Board disconnected
I am trying to create a BLDC Controller project based on VESC using the STM32F405RGT6 microcontroller. I have successfully flashed the bootloader and uploaded the firmware using STLink. However, when I connect the IC to my laptop via USB, the IC is d...
What to change to make speed keep up under load?
I'd like to make our application more aggressive so that it can keep its speed constant under different loads.The speed regulator seems to be dialled in pretty good as it follows our setpoint perfectly fine.However, when I load the motor, the current...
DMeie.2 by Senior II
  • 745 Views
  • 5 replies
  • 2 kudos
X-CUBE-MCSDK V.6.3.1 has no BLDC motor selection
 Hi,I am currently working on a research and development project for a Dual Inverter Air Conditioner, where I need to run a BLDC motor for the compressor in the outdoor unit.I have installed the X-CUBE-MCSDK version 6.3.1 and started exploring its fe...
NamZC14 by Associate
  • 433 Views
  • 1 replies
Code deleted after re-generation
I generated with MC Workbench some code sa use to program an inverter. I want to plot with the monitor the value read from the potentiometer, i.e., the value stored in "rawValue"I had managed to graphically plot on the monitor "rawValue" variable use...
luke514 by Senior
  • 500 Views
  • 3 replies
  • 2 kudos
