STM32 MCUs Motor control
MCSDK 6.3.2 is out !
Dear MCSDK users, MCSDK version 6.3.2 is now available: Download It here. This is a bug fix release and here are the main changes for this version: Motor Control Features: FOC Fixed CORDIC Modulus computation in case of negative alpha value Fixed iss...
GMA by ST Employee
  • 607 Views
  • 0 replies
Board Manager documentation is out !
The documentation of the Board descriptions format is now available on Motor Control Boards Description Wiki page, this documentation is compatible with MCSDK versions from 6.1.2. Board Descriptions are used by the ST motor-control workbench to enabl...
Zied b. by ST Employee
  • 4185 Views
  • 5 replies
  • 3 kudos
MCSDK documentation and your feedback
Motor Control Wiki: STM32 Motor Control Knowledge Database - stm32mcuMC Frequently asked questions (FAQ):Frequently asked questions (FAQ) - stm32mcu   The documentation of the Board descriptions format is now available on the Motor Control Wiki:   Wi...
  • 5176 Views
  • 1 replies
  • 2 kudos
X-CUBE-MCSDK integration with STM32F103C8T6
I want to drive a BLDC Motor using STM32F103C8T6. The said controller is not present in the official support of X-Cube-MCSDK. I want to understand how we can add a new STM32 MCU in the X-Cube-MCSDK. Also, I want to understand does the X-Cube-MCSDK su...
DChan.8 by Associate
  • 476 Views
Arduino & STM32 & Motor controller
Hello, I am a college student working on a project based on the NucleoF446RE board. My goal is to communicate between Linduino board, SevconGen4 (motor controller) and nucleo board. Linduino received data from the motor controller and outputted corre...
Ohaye.1 by Associate
  • 557 Views
  • 1 replies
MCSDK 5.Y.1 G431RB/STDRIVE101 Motor Speed Control
My desire is to find some detailed documentation on the MCSDK 5.Y.1 project generated and how to exercise the motor using the Motor Pilot. Specifically:•   Change the initial startup speed•   Change the speed of the motor (while the motor has already...
ATzou.1 by Associate II
  • 1932 Views
  • 9 replies
Can STEVAL-SPIN3201 be programmed for sensorless 6step? I try to use X-CUBE-MCSDK-Y (6S_STEVAL3201_SL_VM) but when i use the Keil and download it to the board, the motor don't work and i can't connect to the motor pilot 5.Y.1
Hi ST Community,I'm seeking to start a motor with FOC and six-steps to analyze the difference. When i used the FOC example it works fine, but when i change something and download it to the board with Keil the motor control workbench don't connect: Co...
LTren.1 by Associate
  • 338 Views
  • 1 replies
Connecting the L6474 motor driver to an STM32F3
Hi everyone,I am trying to control the L6474 motor driver via an STM32F3 mcu. I am not using the default shield for it, but have it connected directly to the mcu. I know the connection is correct, as this has previously, and still will, work with a d...
DJans.1 by Associate
  • 667 Views
  • 3 replies
