How to manage using external flash in command mode while simultaneously running firmware from it in memory mapped mode?
roganmorrow
My firmware application is stored in external NOR flash which is memory mapped using XSPI and then loaded by a bootloader. However I also need to interface with the external NOR flash in command mode so I can e.g. store a filesystem there. I can't switch out of memory mapped mode because then my application can't run. How am I meant to get around this dilemma?
0 REPLIES 0
