STM32 MCUs Embedded software
Vbus is driven in mass storage mode.
This specifically relates to the same stm32l496 and the USB functionality, specifically creating mass storage mode. I used STMCubeMx to generate the configuration originally, and have since checked that against sample project provided by STM on githu...
VBarb.1 by Associate II
  • 486 Views
  • 0 replies
STM32F4 alternate function mapping confusion
It is very confusing to me how pin multiplexer is explained in the datasheet, it doesnt help the matter when using .SVD file in the debugger as it is even more confusing.Lets start with the SVD file. In the debugger I can see AFRL showing AFRL0-AFRL7...
Gossamer by Associate II
  • 1410 Views
  • 3 replies
STM32F769 IsoINIncomplete callback gets called multiple times in a row but OTG_DAINT register has the value 0x00000000. What can be the reason?
Hi, I am working with the STM32F769i-disco board and develop an usb audio 2.0 device (a microphone array). When I start a recording application on the host pc, the IsoINIncomplete callback gets called multiple times in a row but the OTG_DAINT registe...
MGuen.1 by Associate
  • 710 Views
  • 0 replies
Regarding FreeRTOS
Hi ST Team,Hope all you are Well !!!!I have a STM32F030 Nucelo-64 EV BOARD. I wanted to work on FreeRTOS on this Board. Can you help me how can i proceed on this.
PKuma.6 by Associate II
  • 1024 Views
  • 3 replies
Resolved! F042K6 - stuck in CAN receive interrupt
Hello,I am trying to set up CAN communication on my F042K6 using the HAL library. I have followed the stm guide (attached). I got most of the functionality working, however if i try to use the Rx interrupt using "void HAL_CAN_RxFifo0MsgPendingCallbac...
retro by Associate III
  • 5029 Views
  • 12 replies
Resolved! STM32F411CEU6 "Black Pill" USB virtual COM port code not working, but working on STM32F4 discovery
Hello,I'm using STMCubeIDE, with firmware version: STM32Cube FW_F4 V1.25.0I am trying to implement a USB virtual COM port. My code is working on the STM32F4 discovery board. I then created a new project for the STM32F411CEU6 "Black Pill", but the U...
Gbeau.1 by Associate
  • 7081 Views
  • 1 replies
STM32F76XXX Bootloader Activation
Hi! I'm new to the STM32F76, and I'm attempting to flash the MCU through either a serial/USART connection or USB (DFU mode). I have been unsuccessful and would appreciate any advice.Here's what I've tried:* I've read through AN2606 and have gathered ...
BB.2 by Associate
  • 893 Views
