STM32 MCUs Embedded software
STM32F107 FreeRTOS+NetConn won't work
Hello.I'm trying to stitch-up the STM3210C LwIP TCP/IP Echo client example (my board) and STM324xG LwIP+FreeRTOS+NetConn example.LwIP, and netif config are the same as for Echo example (and previously I ran httpd-raw server with it).I was able to set...
zedeg by Associate III
  • 272 Views
  • 0 replies
Inaccurate us delay function
Hi,I'm trying to implement a `delay(microseconds)` function on an STM32 F745 running at 216 MHz. I want to keep it dummy and simple without involving interrupts. My strategy is as follows:-Setup TIM2 to run at 1 MHz. Since it has a 32-bit counter it ...
CGalv by Associate III
  • 1516 Views
  • 9 replies
X-CUBE-Azure x509, are certificates supported?
I am running STM32CubeExpansion_Cloud_AZURE_V1.1.0With IoTHub SDK 1.2.12 and provisioning client 1.2.12The provisioning client resolves server name as expected, then the iothub client handshakes with the IotHub using MQTT, but the server rejects it.I...
UKluk by Associate
  • 741 Views
