STM32 MCUs Embedded software
USB_WritePacket stuck in infinite loop
  Hello ST Team, I developed a custom USB DFU HOST class on an STM32F446ZE. I soldered a USB-C cable directly to the D+/D-, 5V and GND pins. The Problem: The stack works correctly for transfers up to 128 bytes. However, when I set phost->Control.setu...
Strongato by Associate II
  • 361 Views
  • 13 replies
  • 1 kudos
STM32H503RB I3C private communication(read)
Hello everyone, I'm having some trouble implementing I3C communication and would like to ask for some help. I am using the NUCLEO-H503RB board as my main controller. For the target devices, I have the NUCLEO-IKS01A3 expansion board and the TSC1641 (C...
roro by Associate
  • 51 Views
  • 0 replies
Resolved! Program STM32L471 with HAL_FLASH_Program failed
I am migrating from STM32L431 to STM32L471. After migration, the function relating to internal flash writing does not work any more. The problem is when I programmed internal flash with HAL_FLASH_Program(FLASH_TYPEPROGRAM_DOUBLEWORD, address, data), ...
Huiqi by Associate II
  • 278 Views
  • 9 replies
  • 3 kudos
Zero crossing detection using AWDG
I'm using stm32u535 and would like to have zero crossing detection of supply voltage. I've requirement of 6ADC channels and all are configured in differential mode and adc clock is 25Mhz and resolution is 14 bit and dma circular mode is enabled. On c...
