STM32 MCUs Embedded software
Assembly code to launch an application
I got this assembly code (see below) in an ST example code on secure boot and  and I don't understand some lines :why do we have to push R1 five times in a row?why is LR set to 0xFFFFFFF9? That is causing a hard fault at runDoes anyone have better un...
HABIJ.1 by Associate III
  • 2410 Views
Resolved! EEPROM emulation problem on STM32H563
Hi,I'm facing problem in reading data from EEPROM, which was written before power cycle.EE_Init() always causes formatting of EEPROM irrespective of EE_CONDITIONAL_ERASE or EE_FORCED_ERASE parameter passed, resulting in erasing the previous dataConfi...
Resolved! I2C using the HAL library in the IT mode.
I have implemented a basic I2C between STM32H7 (Main) and STM32F4 (Secondary) processor. I am using an array of size 6 to transmit from the Main CPU to Secondary CPU using I2C in IT mode.The HAL API for I2C requires the data_buffers to be of size uin...
Sahilsb7 by Associate III
  • 3238 Views
  • 4 replies
  • 1 kudos
Resolved! Custom initialization of peripherals
Hello,I am working with timers in a stm32 project. In the generic INIT function that is generated using the .ioc file important functions like HAL_PWM_Init(),  HAL_TIMEx_MasterConfigSynchronization() etc are understandably called outside the user cod...
Avi_8 by Associate II
  • 1507 Views
  • 4 kudos
Resolved! SFR view, wrong address of registers bit field?
I am working with STM32G474RET6U MCU and I would like to check the values of bit filed EXTSEL (ADCx->CFGR.EXTSEL) the problem is that according to SFR view this bit field starts on 6th bit of CFR register, but according to the reference manual it sho...
GHrib.1 by Associate III
  • 1539 Views
  • 4 replies
Problems with osMessageQueue
Hello.I'm using the STM32U5A9J-DK development board to work on a project to display UART data on the screen textArea, and I've made sure that there are no problems with the communication between the PC and the STM32 UART, and with the process of Mode...
