STM32 MCUs Embedded software
EEPROM emulation - EE_Init() fail - Step 4
Hi, I'm using en.x-cube-eeprom-v7-0-0 on a STM32L476 and I got a problem during my validation phase.I do lot of write on the EEPROM to be sure my code works well (so lot of CleanUp).Actually, on the step 4 of the EE_Init(), I have a EE_WRITE_ERROR on...
Dams by Associate III
  • 392 Views
  • 1 replies
  • 1 kudos
TouchGFX with USB cdc Host
Hello everyone,I am developing firmware for the STM32F7469I discovery board, and I'm utilizing TouchGFX for the GUI aspect of the project. However, I am encountering a problem when enabling USB-FS HOST functionality. The GUI and other peripherals suc...
Usb host with touch gfx
Hi everyone..I am using USB host for communication CDC along with touch GFX for grafix which will use RTOS, The usb is not getting ready after the start state of usb what will be the issue, but when I configure only USB CDC HOST with out touch GFX it...
FMC gives no output for LCD
Hello,Apologies if this is posted in the wrong location. I am trying to control an LCD (ST7789) with my STM32U5G9J-DK2 using FMC. In CubeMX, I configured the NOR Flash/PSRAM/SRAM/ROM/LCD 1 to use NE1 and A0 with 16 bits of data. I also ensured to con...
M95P32 EEPROM driver: multiple EEPROM instances?
New question from M95P32 EEPROM - looking for a driver@mƎALLEm Thank you for your advice. Although I need to adapt the code to my needs and lots of refactoring will be needed e.g. to use DMA and RTOS in async fashion, it got me started.There is, howe...
TDJ by Lead
  • 227 Views
  • 1 replies
  • 1 kudos
