STM32 MCUs Embedded software
Resolved! STM32H747IIT6 ETHERNET RMII PROBLEM
Hello,I am using the STM32H747IIT6 microcontroller along with the LAN8742A Ethernet PHY, configured in RMII mode. However, I am facing issues where the Ethernet interface is not working at all in my circuit. It appears there may be multiple bugs or c...
KAnahar by Associate III
  • 1530 Views
  • 6 replies
  • 1 kudos
PDM2PCM(HP) library details
Good morning, if possible, I would like more details about the following PDM2PCM(HP version) library used for converting PDM data to PCM.           typedef struct{ uint16_t bit_order// MSB / LSB uint16_t endianness;// big endian / little endian uint3...
Mavi by Associate II
  • 1337 Views
  • 1 replies
  • 1 kudos
STM32H562 RTC problems
Hello everyone. How are you?I created a test program based on https://community.st.com/t5/stm32-mcus/how-to-calibrate-the-stm32-s-real-time-clock-rtc/ta-p/744958 I calibrated and compared the signal (512Hz @ PB2) with an oscilloscope, resulting in an...
LAN8720 With NUCLEO H723ZG
Hello everyone, I have a NUCLEO-H723ZG board and I would like to establish Ethernet communication with it. The board already includes a LAN8742 chip as the physical layer. However, in my system there is an external LAN8720 magnetic Ethernet module. A...
Resolved! BSP symbols not recognised by IDE
Split from STM32G431CBU: section `.bss' will not fit in region `RAM' as that issue is solved, and this is a new question.One more question. If you can help.BSP_TS_Init e BSP_TS_GetState is not recognized in IDE versions 1.19 and 1.20.Therefore, TOUCH...
Resolved! STM32G0B1KBU USB-C CC2
Im looking to use the STM32G0B1KBU processor including the USB-C interface.I only want to use it as a UPF with VCP and update the firmware, no advanced PD or role switching. The issue is that UCPD1_CC2 is not routed to a pin on the processor.Is it po...
XD by Associate III
  • 348 Views
  • 5 replies
  • 1 kudos
