STM32 MCUs Embedded software
Resolved! Can't enable port B & D clocks
I tried the following code in a STM32F107:RCC->AHBENR = RCC->AHBENR | RCC_APB2ENR_IOPBEN_Msk| RCC_APB2ENR_IOPDEN_Msk;and RCC->AHBENR = RCC->AHBENR | 0x00000008 | 0x00000020;When I display RCC->AHBENR, it always shows 0001C014.I expected to see 0x0001...
vneff by Associate III
  • 1579 Views
  • 5 replies
  • 2 kudos
Resolved! SPI Slave Receive Interrupt
I am trying to make a very simple SPI ISR to read the RXDR and store the value to a buffer. However, I cannot get the ISR to even trigger without using HAL_SPI_Receive_IT(). I do not want to use the callbacks or the default IRQ generated by cube. I c...
How to use HAL_GetTick ?
Dear Members,How can I use HAL_GetTick for time stamp ?Is this right ?or I need something else ?Thankscase PULSE_TRACE_UP: if(sensor_value > prev_sensor_value) { printf("PULSE TRACE_UP\r\n"); currentBeat = HAL_GetTick(); ...
Resolved! Issue in CAN Normal mode with STM32F412
If anyone Work on project that interfacing Can transceiver TJA1050 with STM32F412RET6 , if yes i hope  anyone send Example code that work and clock configurations ,, the loopback mode work correctly .. but in normal mode problems start ... and operat...
