STM32 MCUs Embedded software
Hard fault in ThreadX tx_mutex_put
Hi AllI have a problem with a ThreadX-based project on a Nucleo H563ZI board when using a mutex.The mutex locks access to an FDCAN peripheral, and a message-buffer data structure during CAN-FD message transmission.  The problem only shows up when I l...
MAX1300 interface with STM32f429ZIT6
Kindly suggest the c code for MAx1300 interfacing with STM32F429ZIT6. I need algarithm or source code for Full scale Reading Range from -3xVref and +3xvref.. FSR =24.  that's +12 and -12vDr R RaghunathDhanventhra Bio Sys Chennai India
Raghoo by Associate
  • 273 Views
  • 2 kudos
Bug in GPDMA with 2D addressing (I think)
I believe there's a bug in the stm32h7rsxx_hal_dma code for dealing with repeated blocks in interrupt mode. This bug probably exists in other STM32H7 devices as well.With a typical repeating transfer, in *NON* interrupt mode, the DMA transfer complet...
FA1234 by Associate III
  • 237 Views
Resolved! The STM32 USB device library feels complicated
The structure of the stm32 usb device library feels very complex, is there any tutorial to clarify the structure?I want to implement a UVC.This is a picture I found on a wiki, but I can't make sense of it.For example, the file stm32xxx_ll_usb has no ...
Shiina by Associate III
  • 579 Views
  • 5 replies
  • 6 kudos
Hard Fault
Hello all ,I am facing a issue of hard fault because of some reason however after analyzing issue I  suspect this could be due to  use of structure having uint64_t variable having bit fielding. I have also attached snapshot of issue which I am facing...
devendra by Associate II
  • 230 Views
  • 3 replies
  • 4 kudos
