STM32 MCUs Embedded software
ST patches for MbedTLS 3.6.5
Hello! Quick question about ST patches for MbedTLS 3.6.5 (stm32-mw-mbedtls).Why was the defined(MBEDTLS_MD_SOME_PSA) added here (in library/md.c)?When MBEDTLS_PSA_CRYPTO_C is defined, the only way to define MBEDTLS_MD_SOME_PSA is to define one of MBE...
Moemen by Associate II
  • 234 Views
  • 3 replies
  • 1 kudos
Resolved! rt-thread project
I created project in stmcube32mx for h5 microcontroller and it works if I manually replace bl main to bl entryin file startup_stm32h563zitx.s.If this manual replacing is a bug or on purpose?Jan
Jan27 by Associate II
  • 544 Views
  • 10 replies
  • 3 kudos
Resolved! slow data rate with usb cdc on nucleo-h533
Hi All, I'm building an instrument that needs to stream data to a PC at ~4Mbps. People were claiming nearly twice this with USB CDC so I chose the nucleo-h533 board and started with the Ux_Device_CDC_ACM example. I disconnected the USART code and add...
MScha.8 by Associate II
  • 456 Views
  • 11 replies
  • 3 kudos
STM32L471 BFB2 and FB_MODE question.
Hello,I'm trying DUAL BOOT on STM32L471 and having a problem with SYSCFG->MEMRMP FB_MODE bit.I modified Dual Boot Bank Swap Boot Loader Example for STM32G4 project to fit my board, and everything goes well when the firmware put from the start of BANK...
LWIP freeRTOS and BSD Sockets
Hi, I have started from a project by Adam Berlinger.I have two UDP sockets, one receiving data max 500 bytes/s one sending data 200 bytes every 5 seconds and one TCPIP sending 4K every 20 ms.Netconn Api I have no problem. With BSD sockets, If I work ...
FMarr.2 by Associate III
  • 236 Views
  • 1 replies
