STM32 MCUs Embedded software
Resolved! STM32H743 Timers + ADC + DMA
Hi you all,as a breef summary; I set up a timer to trigger an adc that should than use the DMA to transfer the data to memory, i need 111 samples at a time. Sadly for some reason this only works for one sample so if i check  __HAL_DMA_GET_COUNTER(g_h...
ICT_TAN_0-1768226675241.png ICT_TAN_1-1768226694036.png ICT_TAN_2-1768226722687.png
ICT_TAN by Associate
  • 163 Views
  • 1 kudos
NUCLEO-F401RE + x-cube-ble1: Hard Fault
I’m attempting to learn BLE and IoT and have purchased the following boards to get started.NUCLEO-F401RE    MCU brdX-NUCLEO-IDB05A2  BLE Expansion brdDownloaded:STM32CubeIDE Version: 2.0.0 Build: 26820_20251114_1348 (UTC)STM32CubeMX Version: 6.16.1x-...
Thread safety of code generated by Cube
Hello,I'm wondering if Cube's generated code for is thread safe. In particular, whether malloc can be safely used in a multi-threaded FreeRTOS setup.The broken malloc behavior was first described by Dave Nadler in 2019 here. He has also written about...
unturned3 by Associate II
  • 3374 Views
  • 10 replies
  • 2 kudos
CAM-16GZ driver
I'm using STM32N6 with stm32-mw-camera to communicate to CAM-66GY sensor. I also have CAM-16GZ sensor, but looks like this sensor is not supported (because of VD6G_BAYER_NONE when I use vd6g driver). What are my options to integrate CAM-16GZ into the...
