STM32 MCUs Embedded software
Resolved! TIM1 output compare mode on STM32G070
Hi All, I am trying to generate variable frequency using TIM1 on STM32G070. I use TIM1 in output compare mode and PC8 as an output for channel 1. Pre-scaler is set to 0 and ARR to divider for whatever frequency I want. When checking registers I see C...
vladov by Associate
  • 786 Views
  • 1 kudos
osKernelStart faults to HardFault handler
Hi All I working on a data logger code.   It is basic at the moment.  1, set a an ISRTimmer for 1sec. 2, When ISR triggered set a read bit in Datalogger register i set up. 3, Next loop thru main i test Datalogger register, if set go to a function and...
DaveBy2 by Associate
  • 876 Views
  • 1 replies
X-CUBE-USB-AUDIO multifrequency.
Hi.In X-CUBE-USB-AUDIO, You wrote:1. Does it mean that playback and recording can work simultaneously, and at different sampling rates? For example, playback at 44,1k, and recording at 96k?2. Does it mean that playback and recording may by governed b...
HAL_GetUID functions do not seem to work
The HAL_GetUID functions return the same value on different chips of the same series. I am using an STM32L0 series chip. This is my code:uint32_t serialw0 = HAL_GetUIDw0(); uint32_t serialw1 = HAL_GetUIDw1(); uint32_t serialw2 = HAL_GetUIDw2();Whic...
TIM updated callback
I am using 4 TIMs for updated interrupts functions. in the main while loop, I will call start the timer. and if the timer reaches its full-period and call the callback function. A Flag will be setted in the callback function and print a timeout meass...
HAL_GET_ANSWER_4-1713101863062.png HAL_GET_ANSWER_0-1713101653047.png HAL_GET_ANSWER_3-1713101830921.png HAL_GET_ANSWER_1-1713101715552.png
BMPFileLoader not working for me
HiSo, I want to load images at runtime from the flash memory, I have just started testing this and I found the official post on how to load BMP files at runtime, I copy pasted the BMPFileLoader.hpp and .cpp files, and called them like this:It's like ...
I_ve_got_a_problem_0-1711468162041.png I_ve_got_a_problem_1-1711468327045.png
