STM32 MCUs Embedded software
U5 USBX CDC-ACM Standalone Mode
HiI am in the need to have USB working on the STM32U5G9DK2 board, however I specially do not need ThreadX, so I will configuring USBX in standalone mode. And I do not need to be using UART to complement my sample code as a lot of the sample codes fou...
External Ethernet PHY FOR STM32H743BIT6
Hello,I am working on the STM32H743BIT6 ethernet communication. I am using the external PHY DP83TC814RRHARQ1 for my requirement. I am configuring in CubeMX as USER_PHY under platform settings of LwIP. How can i communicate via external PHY.? Does con...
STM32U585: Generate two separate PWM signals
Hello, I have a STM32U585CIUA and generate a PWM with 125Hz 2ms high and 6ms low phase on TIM1 on PA2.I would like to start another PWM with TIM2 50Khz 1us high and 19us low on the falling edge of PA2, which is then stopped after 200 cycles.In all my...
ProNet36 by Associate
  • 416 Views
  • 4 replies
vd55g1 camera driver for stm32n6-dk
Hi, Is there any code for driving vd55g1 in STM32N6570-DK? It is stated in STMicroelectronics/stm32-mw-camera  that vd55g1 is supported, but I have not found the demo for its use. Could you please provide the demo?
eureka by Associate II
  • 342 Views
  • 1 replies
