STM32 MCUs Embedded software
Resolved! Losing RTC ticks after wakeup timer
Hi   I have a STM32L433 running at 16MHz and having a strange issue.  I have setup the rtc and within the Systimer interupt I display the current time (the systimer is 1KHz and every 1000 ticks I get the second , at this point I read the clock and di...
Resolved! operation of HAL_SPI_TransmitReceive_DMA
This question is about the operation of HAL_SPI_TransmitReceive_DMA.When HAL_SPI_TransmitReceive_DMA(&hspi1 ...) is being transmitted (assumed SPI communication_A) and HAL_SPI_TransmitReceive_DMA(&hspi1 ...) is called (assumed SPI communication_B) SP...
STM32-H7 driver for LAN8670 external phy
Hi, I'm working on project, and as a part of it I need to establish an Ethernet connection between the 2 devices.    The device is powered by STM32H7 MCU which is connected to Microchip LAN8670 PHY (10BaseT-1s). On the other side there is or another ...
vano4411 by Associate II
  • 2991 Views
  • 6 replies
SQLite VFS for ThreadX (former Azure RTOS)
Hi all, I have just released subj. I have tried to contribute it to SQLite directly or to create a CubeMX package but seems that nobody interested, so I have created a standalone repository. I have used STM32H753I-EVAL2 to develop and test it and the...
DmitryR by Associate III
  • 107 Views
  • 1 kudos
input capture mode
hi im using stm32g474vet6 timer2 which is 32bit in input capture mode for finding frequency and width.i can't able to measure more than 400khz frequency. i want to measure 4mhz to 400khz signal, which is 400khz frequency signal and its width will var...
DNS for Server based on Azure / netx-duo
Hi, I have an http web server running on a STM32U575. The system is reachable via USB over RNDIS. How can I teach the server DNS? I have tried to use the mDNS module without success. What is the cheapest solution so that the user only has to enter th...
