STM32 MCUs Boards and hardware tools
Resolved! NUCLEO-H743ZI2 Fault LED is always ON
Hello,I hope you are doing great, I am facing the issue with NUCLEO-H743ZI2 Board, The LD6 is always ON and the IC U2 is getting overheated as soon as we connect the USB cable to dump the code and also unable to dump the code. It would be great if so...
Rohith1 by Associate
  • 100 Views
  • 1 replies
  • 1 kudos
Nucleo-G0B1RE I2C2 Communication
I am using the Nucleo-G0B1RE board for I2C communication with BMS AFE IC. I am able to communicate with AFE if i use I2C1 port. I have tested it with [PB9, PB8] and [PA9, PA10]. If i use I2C2 or I2C3 it doesn't work. In case of I2C2 it only works if ...
