Power management
Wireless Charging solution Wiki
This Topic is used for Wireless Charging solution 1.Mcu C drive code: GitHub - STMicroelectronics/STWirelessCharging-C-Drivers: Standard C platform-independent drivers for wireless charging ICs 2. Python drive code, check attach file "Python_FT260_S...
willzhou_0-1717985741931.png willzhou_1-1734156149269.png willzhou_0-1734155900141.png
willzhou by ST Employee
  • 5872 Views
  • 15 replies
  • 10 kudos
Resolved! STDRIVE 101 ENx Pin
 Dear ST community I would like to use STDRIVE 101 similar to STEVAL-POOL4A board (s. schematic above). But to reduce number of PWM pins used I'd like to pull all the ENx pins to VDD (e.g. +3.3V) and drive only INx's pins by an advanced timer. Accord...
STEVAL-DPSTPFC1 source code and BINARY code
hello,I have STEVAL-DPS334C1 and STEVAL-DPSTPFC1. I am trying to put PFC code on STEVAL-DPS334C1 again. I load bin file via stm32programmer. then STEVAL-DPS334C1 crashes. I need source code to find where the error is coming from. Or if you have any s...
L6986 - Output voltage problem
Hello,I have a problem with the output voltage of 3.3VWith input power up to 6V everything is fine. But when I increase the voltage up to 24V, the output voltage slowly changes from 3,3V to 2,8V. The load is about 50mAI can't figure out what the prob...
Unable to understand the value from STPM34
I am using this code to read the RMS Voltage and Current. I am also able to get output which I have attached as a .txt file. The expected voltage from the hardware which I am using STPM34 is up to range of 20 V. I am unable to understand where I am g...
vivek_7 by Associate II
  • 86 Views
  • 0 replies
Resolved! measure motor load torque using the FOC Iq current?
I would like to measure motor load torque using the FOC Iq current. Am I correct that torque should equal Iq*Kt. I am using the ST Motor Control SDK 5.4. I have characterized the Kt of my motor. I calculate Iq [mA] = Iq_s16 * VDD [mV/(Rshunt*Gain*655...
jcysyk by Associate II
  • 1001 Views
VIPER06 device marking
Please advise me where I can find the device marking for VIPER06HN. I was expecting to find it in the datasheet but it doesn't appear to be in there.What is the meaning for CHN on the top right side and for F04250 on the bottom right?Thank you.Paolo
Paul79 by Associate
  • 218 Views
Power Backup by Super capacitor
    hi ,Aiming to have few minutes power  back up for  STM32 mcu with SD card incase main supply 5v goes OFF condition . Timer added for capacitor  charging time since initial current is will be little high .The above is setup enough ? or something s...
MMARI.1 by Senior
  • 217 Views
STPM34 UART communication with ESP32
I have developed code in arduino IDE , I am only getting the output receive from UART 04000A075 . I understand that this is the default value in register DSP_CR1. Could someone please tell me what does this mean.I hereby provide the code for receivin...
  • 1342 Views
  • 10 replies
