Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! S2-LP
Hi, I'm working on a pcb for a student designed 3U CubeSat. We are looking at using your s2-lp transceiver. In the datasheet you include an application diagram, however the components are not given any values. Are you able to provide the capacitor an...
Vnd7020 self internal diagnostic
Hi community I am working with gate driver vnd7020.I have already implemented the reading of the current (I) for both 2 oyputs and temperature for every chipNow i want to implement the self diagnostic from the driver.I want to detect the overload and...
SGasp.1 by Senior
  • 607 Views
  • 0 replies
PD55003L-E impedance related inquiries
Hello, my name is Choi Jae-yoon, and I am the Assistant manager of Sonartech in Korea.I have an inquiry regarding the impedance of the PD55003L-E product. 1. In the data sheet, impedance data is indicated only for the 480MHz to 520MHz frequency band....
Resolved! Finding a Mosfet suitable
I am building a high voltage fence controller, it requires a IRF820 Mosfet 500V 4A  N-channel. Apparently they are not manufactured anymore, and I can not find one anywhere, when trying to find out a replacement I am hitting brick walls with most peo...
5608920 by Associate II
  • 1950 Views
  • 4 replies
Resolved! High frequency alternative to vn5e160str-e
I'm successfully using vn5e160str's to drive some high current outputs, but it would be useful if I could multi-purpose these outputs to support high frequency PWM. The vn5e160str seems to max out at about 50kHz, and I need a stable 800kHz.The PWMd l...
trullock by Associate
  • 1020 Views
Resolved! Suggestion about (broken) F746ZG Nucelo Board
Good Morning,I am the proud possessor of a Nucelo 746ZG board that has served me well since it has been given to me.Unfortunately for ther last week the Nucleo has a text file with inside the string "The interface firmware FAILED to reset/halt the ta...
MMast.11 by Associate III
  • 1662 Views
  • 4 replies
  • 2 kudos
memory read failure
hi I am using M95512 512kb EEPROM connected to FPGA via SPI when Iam writing and reading the data (in single address(0000)) below sequence is followedstep 1: wren instruction is sending.(06)step 2: write data to memory array.(02)step 3: check WIP sta...
Renuka by Associate
  • 802 Views
  • 1 replies
