Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Hardware datasheet M22050431A
Hello, I have looked many places, including Google and the ST website, and I cannot find this microcontroller anywhere. Markings on this controller are the following:6242MCHHES-02-03M22050431Aif someone can provide any information on this and a datas...
how import git project?
how to import this project: https://github.com/lucysrausch/stm32-turbotronik ?I test importing with (EGit - integration for Eclipse 6.7.0) extension from Eclipse market, but not success (Build icon is not active) same if importing from local director...
kliurka by Associate II
  • 3501 Views
  • 8 replies
  • 5 kudos
Resolved! how to power a 24volts electromagnet
i am using electromagnetic sensor which is 24volts. in that i only have the connections for power voltage(positive) and the signal. when i am trying to power it with my stm32f411re nucleo board i can see that the power isn't sufficient. so can i use ...
suhfi by Senior
  • 7340 Views
  • 21 replies
  • 6 kudos
EEPROM (M95P08-I) Safety register
Hi , I am using an M95P08-I SPI EEPROM . And I can now write/erase/program the EEPROM successfully. But I tried reading the Safety register format (RDCR) and found that the Power-up flag (PUF) bit and the Erase flag (ERF) bit were 1.Aften  tried usin...
1123 by Associate II
  • 669 Views
  • 0 replies
DMX512 with stm32F103
i am trying to receive DMX512 signal on my stm32F103 Board but initially i just wanted to see if the interrupt is working , but it did not , so i saw if there is any Framing error but the SR was 192 , which suggests that there is no errors in the fra...
Aniket by Associate II
  • 776 Views
  • 1 replies
Resolved! Connecting from 5V sensor to 3V3 adc channel
Hello everyone,I want to make an adc reading using STM32F103C8T6 but I am really confused. first of all, the sensor I will use is the hall effect open loop current sensor ‘L31S300S05FS’ model. this sensor has 4 pins VCC GND VOUT VREF from these pinsV...
Screenshot from 2024-10-02 17-57-23.png Screenshot from 2024-10-03 10-50-57.png
FinFet by Associate II
  • 1849 Views
  • 4 replies
  • 2 kudos
doubt memory chip hdd bios
1) I spoke to a hard drive specialist and he said that the BIOS of 2.5" and 3.5" HDDs is recorded on these memory chips but I don't know what type of memory and retention timethe models:The 8pins (4 pins on each sides) with 25P05VP、25P10VP、25F512、25F...
ÍStef.1 by Associate II
  • 2667 Views
  • 10 replies
