Others: hardware and software
ULN2804A SOC18
Hi, I can't find the ULN2804A with SMD SOC18 surface assembly, my question is,can I replace with the unl2803a SMD SOC18 ?n practice I have to repair an electronic card,I found all the components excluded the ULN2804A with surface assembly Soc18,which...
Franco1 by Associate
  • 1094 Views
  • 1 kudos
Resolved! Page write mode on M24C64-A125
Dear ST Community, Currently using the M24C64-A125 as EEPROM. We have a performance challenge in which we need to write a certain amount of data in less than 100ms. We checked the datasheet and we found out that The Page Write mode allows up to 32 by...
RachidBen by Associate II
  • 1141 Views
  • 4 replies
SMPS Restart Problem
I have designed a 24v SMPS(switch mode power supply), but it is restarting what is the reason for that, I have used viper38hd IC.Here I attached my schematic, ic datasheet, and transformer datasheet.
Thivanka by Associate II
  • 3389 Views
  • 6 replies
  • 2 kudos
Resolved! MTBF of ATECC608A-MAHDA-T
  Dear Technical Support, Could you provide me the MTBF of ATECC608A-MAHDA-T and the temperature which it was determined and the energy activation value? Thank you so much, María
Recommendation for STBC15LJ footprint
Hi,I'm planning to use STBC15LQ in a design, but I'm finding some contradictions between STM's AN4208 (an application note about flip chip bonding) and a very brief recommended footprint in the STBC15LQ datasheet.Can someone verify that the footprint...
ST10FLASHER translator to hex file
Posted on October 26, 2012 at 20:39As some of you may know, the ST10FLASHER provided by ST does not allow you to save target flash memory as an Intel hex file, but only as a formatted text file. For most, this may not be an issue, but I was in a sit...
