Others: hardware and software
Request product confirmation
HiThe product in the picture we attached is damaged and is about to be replaced.It is difficult to find information about the products below.Can I get the same product?Also, is this an EEPROM?Answers I'll wait.thank you.
YPark.6 by Associate
  • 599 Views
  • 3 replies
Resolved! AS21P2TLR peak switching energy
I have a capacity of 40nF on the S2 pin, charged to a voltage of 3.3V.The D pin is at GND. The 40nF is then discharged through the analog switch. The peak current will be around 6.6A for a very short time (if the analog switch has 0.5 Ohm resistance)...
MSchi.3 by Associate
  • 407 Views
  • 1 replies
  • 1 kudos
Top Marking on UFDFPN5 for M24XXX chips
What is the top marking for the following components?M24C32-FMH6TGM24C64-FMH6TGM24128-BFMH6TGThese are all UFDFPN5 packages.When marked with "4E", is that engineering samples?Is the marking "4EFT" for any of the above points?Thanks in advanced!BR,Frí...
FSigu.1 by Associate
  • 593 Views
ST M24C02-FMC6TG
I need a formal MTBF/FIT/Reliability report for the subject PN for my product life prediction. Thanks.I need to see the FIT's at different confident levels, temperatures, ..etc. Is there a site link I can obtain the data similar your competitors offe...
TPak.1 by Associate
  • 392 Views
  • 1 replies
