Others: hardware and software
Chip idea
Future time requires minimizing the cost of chemical elements. In addition, robotics is gaining power. Your chips will improve. It will be necessary to reduce the nodes, microcircuits and their functions. The work of microcontrollers in closed contai...
ssm by Associate II
  • 715 Views
  • 3 replies
  • 1 kudos
Can anyone provide me the spice model of an obsolete (not so obsolete as I purchased it in 2019 December) diode with the model number STPSC1206D?
I even tried to find the model (STPSC1206D) on your new rectifier simulator with the following URL:https://eds.st.com/schottkyferd/Even though as per STM the mentioned part number is obsolete I need the spice model as it is a significant part of my P...
AKuma.39 by Associate
  • 494 Views
About operating voltage of ST_M24512-r.
We would like to confirm questions below.ST_M24512-r1. Do you have datasheet for information about SCL speed and minimum Vcc? 2. Is our understand correct that the minimum Vcc of ST_M24512-r is 1.8V with our using SCL 400 khz ?      3. Related no.2. ...
TKron.1 by Associate
  • 422 Views
