how import git project?
  • October 10, 2024
  • 3 replies
  • 3256 views
how to import this project: https://github.com/lucysrausch/stm32-turbotronik ?
I test importing with (EGit - integration for Eclipse 6.7.0) extension from Eclipse market, but not success (Build icon is not active) same if importing from local directory.
Thanks in advance for help
Pavel A.
October 10, 2024
Click on green button <Code> , select "download ZIP".
Andrew Neil
According to the knowledgebase article linked by @mƎALLEm,  that won't work - because it won't fetch submodules
Pavel A.
October 10, 2024
That repo does not have submodules.
And it is not an Eclipse project at all. Just a makefile project.
mƎALLEm
mƎALLEm
Are you using STM32CubeIDE?
I recommend to import the package with git and refer to the link I shared before.
kliurkaAuthor
STM32CubeIDE
Version: 1.16.1
Build: 22882_20240916_0822 (UTC)
@mƎALLEm wrote:
See this article: https://community.st.com/t5/stm32-mcus/downloading-stm32cube-packages-from-github-correctly/ta-p/725288
same problem - not active Build
mƎALLEm
Not sure what do you mean by not active build.
Cloning the github link you shared using this git command and succeeded to get the repository:
git clone --recursive https://github.com/lucysrausch/stm32-turbotronik
 Now I don't see any STM32CubeIDE project in it.
So need to contact the project developer on how to build the project.
