LPS22HB coated by moisture-proof coating
When we applied moisture-proof coating to the substrate, we also coated the LPS22HB.In this case, does the coating affect the measurement?If so, is it okay to rub the sensing area to remove the coating?
Is the accelerometer temperature output in OUT_ADC3 still 8 bits if the LPen bit in CTRL_REG1 is cleared?If that is the case, does the temperature change with one digit in OUT_ADC3_H per °C?
I have enabled 2 interrupts on the LIS3DH all on the I2C Bus :1) Data Ready Interrupt 2) Orientation Change InterruptBut during runtime only the Data Ready Interrupt is working. While reading the INT1_SRC register no value is generated. Even after di...
I need to connect Microphone to BlueNRG-2 and How Can I interface with the Chip.?
We understood the ODR and correlated filtering. A following micro-controller application performs further filtering with averaging values to 10 per second. Aimed is calculating an angle derived from the rotational speed. Precision should be about or ...
Hi!We configured it fifo contineous mode to further reduce the current consumption of the lsm6dsl mounted on our own board with nRF52832(nordic semiconductor), but rather the current consumption has increased. Total current consumption has increased ...
Hi,I have a MKI109V3 and one MKI197V1.I have downloaded the related tools&software of MKI109V3 then I opened the DfuSe Demo from en.stsw-mki109w / MEMS_Demonstration_Kit_SW_package_v8_0_WINDOWS and upgraded ProfiMEMSToolV2.40.1.dfu from ProfiMEMSTool...
Hi, how much is the additional current consumption enabling the FSM on LSM6DSOX? Regards
On a workshop I heard of this. For an application I would need a bit more precision especially in gyro resolution / stability. Can you please send me information on this and the MEMS identifier, eg ISM330HLC or ISM330DHC ... Are samples available, e....
I'm setting up LIS2DW12 to 100Hz, low power mode 1, fifo threshold 30 and fifo interrupt on INT2.When interrupt is received by MCU (STM32L4 here) i readout register 0x2F to know how much samples is to retrieve, then retrieve them all by issuing read ...
