MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Health monitoring wrist based device
Hi,we are developing wrist based health monitoring device to measure following parameters.1) Heart rate,Spo2,Blood pressure.2) Gps Tracking.3) Accelerometer.Please suggest the sensor modules for measuring above parameters.or suggest us if u have any ...
ab.7 by Associate II
  • 837 Views
  • 1 replies
VL53L1X, time data
Hello, I have bought VL53L1X to use it on a physics project. My project is about measuring the speed of light in air and some other fluids. As far as I understand, this sensor does not measure distance directly, but measures the time delay between th...
Sthe .1 by Associate
  • 955 Views
  • 3 replies
Hi i have a problem with a sensor vl53l0x on the board b-l475e-iot01a. In particular when i use the VL53L0X_PROXIMITY_GetDistance() in a task with HAL_Delay() it work but when i use the osDelay it work only for a repetition of the for(;;).
If i use 2 task, and in first task put the VL53L0X_PROXIMITY_GetDistance() with osDelay, second task never start. I tried to replace osDelay() with other function for context switch but i have same problem.
Local Communication by using multiple VL53L1x
Hi, I plan to use a VL53L1x sensor pair to implement a very low-bandwith local communication as a side duty of ranging. For this purpose I need to be able to precisely control laser emission of VCSEL. Is is possible to timing VCSEL laser emission by...
CBila.1 by Associate II
  • 1289 Views
  • 3 replies
VL53L1X Dust and Waterproof Protective Material
Is there a way to use the VL53L1X sensor to be dust and water resistant? I watched the Calibration-Free Dirty Environment Cover Glass Solution video and does this protective glass layer also provide water resistance?
