I am using the ISM330 for measuring Acceleration and Gyro data. Both are set to ODR=416Hz. The FIFO is used in Continues Mode with an ODR=416Hz. The Problem is, that sometimes the data in the FIFO seems to be shifted.
Is there a Problem when the Sensor is sampling and doing a i2c communication(reading the FIFO) in parallel?I saw that, that the FIFO gets shifted(or data is overwritten) a few times during collecting data.Can someone help me please?Best Regards,Chris...
