MEMS (sensors)
Resolved! LIS3MDL AMR
Hello,I searched the forum and found out a topic regarding the sensing technology of LIS3MDL sensor. The topic mentioned that LIS3MDL is a TMR sensor, however no support documents are included to further investigate the integrated circuit of the sens...
NiSpan by Associate
  • 80 Views
  • 1 replies
ECompass debagging impossible.
Hello,can anyone tell me what I am doing wrong?For example, I can't get app_mems.c (eCompass) to debug.The debugger does not stop when I set a breakpoint on subsequent function calls because, for whatever reason, the “SensorReadRequest” always has th...
RGünt.1 by Associate II
  • 95 Views
  • 3 replies
LSM6DSM instability and high current consumption
We have an issue with LSM6DSM and LSM6DSV. Sometimes they start consuming abnormally high current of 2.5 mA, which is about 200 times more than normal. Most reliably this can be reproduced when their SPI clock input pin 13 is driven by a week 47k pul...
IIvan.22 by Associate III
  • 105 Views
  • 0 replies
Cant initialize sensors ISPU getting started example
I'm working through the "Getting started with the X-CUBE-ISPU software package for STM32Cube" tutorial and trying the ISPU_Logging example.NULCEO F411RE -> X-NUCLEO IKS02A1 -> STEVAL-MKI229AA (LSM6DSO16IS)(This is also my first time using the Cube ID...
LSM6DSO
Hi, community,   I have a bespoke board running an rp2040 and have been coding the LSM6DSO from the spec, along with using web-found python and cpp examples as starter code. There are several things I haven't found enough detail on and would like hel...
How to improve step count or pedometer accuracy?
Hello Team ST and Community,I have following code for step count for our wrist-based device. We use LSM6DSO IMU.The step debounce threshold has improved the step count accuracy. It is currently set to 20. But, I could not get rid of the false positiv...
ASoni.2 by Associate III
  • 178 Views
  • 1 replies
Resolved! Accelerometer ISM330 - Sampling frequency configuration
Hello, In general, I would like to better understand the relationship between the sampling frequencies of the FIFO and the Accelerometer (ISM330) and how to adjust them correctly for my application, could anyone give an example? In my case I have the...
famadeu by Associate
  • 149 Views
  • 1 replies
  • 1 kudos
