Interface and connectivity ICs
WIFI DIRECT MODE and 3G/4G connectivity
Posted on April 11, 2017 at 12:12Hi All,I need some suggestion regarding my project.I want  my device to send data in wifi direct mode to the Android device which has 3g/4g connectivity.The Android device  will then forward the data to the server , ...
Bluenrg_ms simultaneous master&slave
Posted on April 04, 2017 at 11:46Hi,I'm currently using a bluenerg_ms module; i've managed to make it work in slave and master mode (separately), and i'm now trying to wrap my head around the master&slave simultaneous mode.What i currently do is to ...
BlueNrg-1 evaluation current consumption
Posted on April 04, 2017 at 12:11Hi,I'm using the BlueNrg-1 evaluation board. Built the chat application server mode.Added BlueNrg_sleep() to the main loop.Checking the current at JP4, I'm getting about 160uA-250uA current during advertising and con...
isak by Associate
  • 337 Views
  • 0 replies
BLUENRG-1 standalone
Posted on March 30, 2017 at 13:05Hi All,I have question about BLUENRG-1, can it run as stand alone without another MCU?If yes, I would appreciate very much if you could refer me to some references.Regards,Nav Dev.#bluenrg-1 #standalone-mode
Nav Dev by Associate II
  • 1051 Views
  • 4 replies
Firmware for BlueNRG-MS
Posted on March 30, 2017 at 18:34I am communicating with the BlueNRG-MS over SPI using an ST eval board with an F1 micro. I am able to send data over the MOSI line and receive the 0x2 ready data as shown in the attached image. I am having issues wit...
daithi62 by Associate II
  • 570 Views
