Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
VL53L5CX Operation Theory
Hi, I was wondering if there was additionaly theory avaliable about the operation of the VL53L5CX TOF sensor? I've already read the datasheets and applications notes. I'm particulalry interested in how the SPAD array identifies the transmitted light ...
David01 by Associate II
  • 2250 Views
  • 4 replies
VL53L0X inaccurate off-perpendicular?
I'm using the VL35L0X.ino demo code on an Arduino UNO and a clone VL53L0X sensor. I very carefully measured the off-perpendicular distance measurements obtained from the VL53L0X and compared them to actual tape measure measurements. On average there...
FPayn.1 by Associate III
  • 2116 Views
  • 6 replies
Resolved! VL53L5CX status Mean
when I use VL53L5CX and get a status, then check with the table, but I still need further description than can explain STATUS means what.It's better like the picture below. Now I meet status 2, but I do not know why this happened.
MasterNi by Associate
  • 1783 Views
  • 1 replies
Resolved! Long Range TOF
Hello, I want to ask about the maximum range of VL53L1CB, as it says in the table (as seen in attached photo) that it's up to 8m. However, in data sheet or specification just says over 400cm.1) So is the performance should be good at 8m range outdoor...
E_K by Associate
  • 2283 Views
  • 1 replies
VL53L5CX ULD vl53l5cx_check_data_ready() returns error CA 81
I'm trying to implement the VL53L5CX ULD v1.3.4 on an Atmel ATSAM4L. Per an Total Phase I2C analyzer, I have it almost all running correctly. It's uploading the firmware, and the firmware bytes captured by the I2C analyzer match the bytes in vl53l5cx...
DBonh.1 by Associate III
  • 4396 Views
  • 8 replies
Resolved! VL53L4CX not NewDataReady
Hello, i've been using a couple of VL53L4CX tof for a month with no problem so far, but recently i bought a few more and none of these work. (These new ones are the same model that the ones that worked).Analyzing with a digital osciloscope the I2C co...
JaFrauca by Associate
  • 1906 Views
Resolved! VL53L5CX sunlight range
Please tell me the brightness range of sunlight that VL53L5CX can be used with.
Taro by Associate
  • 1596 Views
Resolved! User Manual for STSW-IMG035
Howdy,I am working on a project that utilizes a VL53L5CX ToF Sensor, and I am looking to use the STSW-IMG035 libraries for M0+ chips in my project. In the databrief for the sensor, it refers to "an easy-to-read user manual" which I cannot seem to fin...
adirt by Associate
  • 1044 Views
  • 1 replies
Resolved! Unable to start ranging on the vl53l8cx
Hello,I've already used the vl53l5cx and it worked flawlessly, so I decided to try the newest one. I'm working on an esp32s3 and a satel-vl53l8 using the ULD. I completed the platform file, and it initialized the sensor without errors. But when the s...
RJRP by Associate II
  • 2494 Views
  • 3 replies
