Imaging (sensors)
about connection of pins in VL53L1X
Dear Sir,We are going to make our own PCB after confirming the action with X-NUCLEO-53L1A1 module. We found the connection of pins 4, 6 12 in VL53L1X breakout board is different with the Figure3 (VL53L1Xschematic) . In Figure 3, pins 4, 6 and 12 ar...
DSai.1 by Associate III
  • 400 Views
  • 1 replies
Strange behavior of the VL53L0CXV0DH sensor.
Strange behavior of the VL53L0CXV0DH sensor.I get the correct data (distance to the obstacle), with a normal change in the position of the obstacle (zoom in / out), the data changes correctly and corresponds to the real distance.If the obstacle is sh...
RPavl.2 by Associate II
  • 2251 Views
  • 18 replies
VL53L1X Reading data
Hi,I can read the VL53L1X sensor data via i2c. But the values are not consistent when I keep my object from 1cm to 20cm the values are not accurate and not matching with the distance level.Regards,Kumar
Akuma.6 by Associate III
  • 1008 Views
  • 6 replies
about schematic for VL53L1X
Dear Sir,We will make our own PCB for VL53L1X application. There are some difference betweenVL53L1X breakout board schematic in UM2359 and VL53L1X schematic in the datasheet.In Figure3 of datasheet, pin 4, 6, and 12 are connected to ground directly....
  • 435 Views
Is there any way to know the basic control related commands of the VL53L5CXV0GC chip? Can't the st microelectronics customer technical support center help with this? If neither is possible, should I apply and use only the provided f/w for Eva Board?
I We purchased this sensor to apply it to our own board. I want to know the command to control the sensor on the board, but the data sheet only provides for simple i2c communication and address, index, and data structure.
YJu H.1 by Associate
  • 647 Views
Resolved! Help on issues found in VL53LX API v1.2.8?
I'm using the latest API version (1.2.8) available from the VL53L4CX product page.In my project I have implemented an interface to set configurations or run calibrations.I am also using this driver for both the VL53L4CD and VL53L4CX, since the driver...
AGreen by Associate II
  • 714 Views
  • 1 kudos
Resolved! STSW-IMG035 Minimum Resource Requirements (DMIPS) on HOST MCU
Hi all,i'd like to know the typical resource requirements (mainly required computing power / DMIPS value) of running the TouchLessControl library (STSW-035) library on a host MCU. The GestureEVK-UM.pf mentions a typical RAM and FLASH footprint :I k...
LK by Associate II
  • 1132 Views
  • 1 replies
