Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
Resolved! Drivers for VD56G3 Camera Sensor with STM32N6
Related posts* https://community.st.com/t5/imaging-sensors/integration-support-for-vd56g3-camera-sensor-with-stm32n6/m-p/822221#M5767* https://community.st.com/t5/imaging-sensors/drivers-for-st-brightsense-image-sensors-for-stm32n6-series-%CE%BCcs/td...
Resolved! VL53L0X mechanical sizing information
We are developing sensing device with using VL53L0X,  we will use optical lens on top of  VL53L0X  for special sensing purpose then in order to optimize lens design with effecive sensing, we would like to know dimension of both sensor and emitting ch...
Hide1 by Associate II
  • 1070 Views
  • 7 replies
  • 1 kudos
Using VL53l0x with DMA
I have an application that needs to use several VL53l0x ToF sensors. The measurements need to be fairly responsive to a slow moving object approaching the sensor; so something like taking readings at 10Hz would be reasonable.  Having tried a quick pr...
MikeB100 by Associate II
  • 295 Views
  • 1 replies
VB1940 Pinout
Hi ST Support.I am currently working with a camera module using VB1940. I could not find a detailed pinout or pin definition in the official documentation. I would greatly appreciate it if someone could help me with that.Thank you very much for your ...
Atoskdke by Associate
  • 387 Views
  • 1 kudos
Confusion on the VL53L1-SATEL registers
Hello, I am currently trying to write code for the I2C communication with the VL53L1-SATEL board. I was trying to confirm that the I2C was working by reading some registers mentioned in the VL53L1 Datasheet, those being 0xC0, 0xC1, 0xC2, 0x51, and 0x...
Carson by Associate III
  • 420 Views
  • 4 replies
  • 2 kudos
Resolved! Source available for STSW-IMG041 Device Code ?
Hi,I would like to know if the STSW-IMG041 code that is flashed into the device is available somewhere. My goal would be to use the same code but on a custom board to verify that the sensor is working properly.Thank you!
MikeReg by Associate II
  • 366 Views
