YMand.6
Hi I am trying to validate the .txt file a custom data over 'validate on desktop' option over cube ai but process is not ending at all. Is it necessary that data must be validated on target only.
  • March 19, 2019
  • 4 replies
  • 2699 views
    Gln
    Hi @Community member​ ,
    Custom data validation can be done on desktop and on target. As described in the X-CUBE-AI User Manual, in section 14.2 Custom data set file format?:
    "The expected file is a simple text file in csv format with one flattened input tensor by line. The comma is used as a separator."
    When you say the "process is not ending at all", is there any additional information displayed in the STM32CubeMX Output log window? (Window -> Outputs)
    Best regards,
    Guillaume
    YMand.6
    YMand.6Author
    hi
    I am following the similar process. Please have a look at data file
    YMand.6
    YMand.6Author
    hi
    Gln
    Looking at your actitracker_raw.txt, it seems that your values are encoded as followed:
    # Expected Class Nb, Expected Class Label, Timestamp, In X, In Y, In Z
    33,Jogging,49105962326000,-0.6946377,12.680544,0.50395286
    33,Jogging,49106062271000,5.012288,11.264028,0.95342433
    33,Jogging,49106112167000,4.903325,10.882658,-0.08172209
    Your custom dataset file should online include input tensors, that is, assuming your input tensor dimension is 3:
    # In X, In Y, In Z
    X-CUBE-AI version 3.4.0 allows you to dump NN inference input and output data. If you look at your log when executing a validation, you should be able to see the creation of 3 files:
    Creating C:\Users\<username>\.stm32cubemx\ai_valid_inputs.csv
    Creating C:\Users\<username>\.stm32cubemx\ai_valid_outputs_model.csv
    Creating C:\Users\<username>\.stm32cubemx\ai_valid_outputs_c_model.csv
    Guillaume
