undefined reference to `osalThreadSleepS'
berardo
Posted on October 31, 2013 at 12:20
i have a question.
Bulding CAN code based on example for SPC56ELx produce this error:
build/obj/can.o: In function `canStart':
can.c:(.text_vle.canStart+0x2c): undefined reference to `osalThreadSleepS'
collect2: ld returned 1 exit status
make: *** [build/out.elf] Error 1
CAN configuration it is same that example.
But i have added Chibios.
I have replaced osalThreadSleepS(1) with osalThreadSleepSeconds(1) in :
C:\SPC5Studio\eclipse\plugins\org.chibios.spc5.components.spc5hal_1.0.0.201310031641\component\lib\src
But it seem  not correct.
Why compiler don't find function
osalThreadSleepS
?  there are conflicts with Chibios?
#osalthreadsleeps #can
Posted on November 08, 2013 at 10:18
Thanks for reporting, it is a confirmed bug, the problem will be fixed in next release.
The workaround is to edit the file C:\SPC5Studio\eclipse\plugins\org.chibios.spc5.components.osal.spc56elxx_1.0.0.xxxxx\component\lib\src\osal.c
And change
inline void osalThreadSleepS(systime_t time) {
with
Giovanni
1 REPLY 1
And change
with
Giovanni
