Automotive MCUs
How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! SPC574S Reference Manuel
Hello, I need this document as soon as possible. I could not find anywhere.Regards
Msert.1 by Associate III
  • 620 Views
  • 1 replies
Resolved! DMAMUX configuration example for periodic triggering
Hi all,I seem not to be able to achieve periodic DMA transfers using DMAMux periodic triggering functionality.I read on SPC574Kx reference manual that (§7.3.9.2)DMAMUX1 receives PIT_0 Trigger 0-4DMAMUX2 receives PIT_0 Trigger 5and that (Table44):PIT_...
CoolMo by Associate III
  • 820 Views
Resolved! BDSL File Request
I would like to request the BDSL file for PN#SPC58NN84E7RMHBR.Can someone help to check and advise?Thanks.Regards,Kent
KLiew by Associate
  • 501 Views
Resolved! CI Build Options
Hello, Has anyone successfully implemented headless builds for SPC5 studio? I am looking for information on this with the intent on creating a docker image to build new binaries at each commit with the usage of bitbucket pipelines. Any assistance wou...
NMazz.1 by Associate II
  • 822 Views
  • 4 replies
Resolved! SPC58xNx : ECC Error Injection in DFlash
My requirement is to 1) Inject ECC error in DFlash2) ECC has to be detected, but there should not be any reset as it occurred in DFlashWhat are the registers to be set for the above steps?Note : I tried sample programs from SPC5Studio* FCCU Test Appl...
SP.4 by Associate
  • 477 Views
  • 1 replies
SPC58xNx : ECC Error Injection in DFlashMy requirement is to1) Inject ECC error in DFlash2) ECC has to be detected, but there should not be any reset as it occurred in DFlashWhat are the registers to be set for the above steps?Note : I tried sample p...
SP.4 by Associate
  • 597 Views
  • 1 replies
Resolved! SPC570 CAN outputs bad frame, independent of frame parameters
Hello,I am currently trying to transmit CAN frames from my SPC570S-DISP board. The board is connected to a verified working CAN node that is expecting frames at 500 kbps. I am able to write to the CAN buffers and get the CAN core to transmit, but it ...
AZayt.5 by Associate II
  • 1743 Views
  • 7 replies
