Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
How to use ICU for channels in eMOIS0 Group1 with SPC5Studio?
Hi,I am using SPC584B70E3 and I want to configure some of the inputs as an ICU. However, the SPC5Studio Limits the ICU for eMIOS0 Channels 0-7 only. I cannot configure PE[0] (eMIOS0 Channel 11 or eMIOS1 Channel 13) as ICU for instance. In the Referen...
TUyar.1 by Associate
  • 2058 Views
  • 5 replies
UDE Workspace refers to older source files
Hello,I normally copy an old SPC5 project and paste it with an updated version number to modify the source code. But, the copied UDE workspace is referring to older source code. Can you help to fix it?Thanks in advance.Br,Sreejith
SKara.7 by Associate II
  • 1011 Views
  • 4 replies
Resolved! Issues with flash programming -SPC584Bxx
After flash programming, the program doesn't run once I disconnect the debugger and do a power cycling. Can somebody help me to find what the problem is? I use the attached build settings for Hex file generation in SPC5 Studio.
  • 1562 Views
  • 5 replies
Resolved! SPC58xHx BAF code loops in infinitely after reset or re-powered
Dear Experts,After erasing all flash, I flash new program to SPC58 and it can just work as soon as flashing the application execution file (e.g. elf).My SPC58 cannot run the application code after reset or re-powered.Based on the SPC58 H Line Referen...
HNguy.20 by Associate
  • 1529 Views
Resolved! MCAL drivers for SPC560 and SPC563
We have MCAL drivers for MPC560 and MPC563 microcontrollers (AUTOSAR 3.0 and 4.0).Can we use them to write MCAL drivers for SPC560 and SPC563 microcontrollers?
